outer 1/4 window trim
The windows are encapsulated which means the rubber is made on the window. If you only need to replace the chrome it can be done but if it is a show car you should buy another complete window. The rubber also runs through holes in the chrome to hold it together. You can cut this part down in the channel & remove/replace the chrome but it may not lay perfect afterwards because of this.
that figures... I've got a piece of glass because it was busted before and someone rigged it with lexan. I guess I'll be lookin for a whole assembly then
I'm a little confused now.. so I'll need to find a window assembly for a landeau car or just the glass and outer chrome ring from either style roof and reuse my rubber gasket?
Niiice...I finally got a rear....w00t!
And I just got a pretty package in the mail from Eagle....:D
You need a whole window assembly and you need it for a landau if you have a landau. The rubber protrudes past the chrome less on a vinyl top car.
