Alright the plug with the visible oil on the ceramic and nut is #6 and truth be told i took it to the track last saturday and well something happend im not sure what yet anyhow she lost some coolant and some oil on the 4th or 5th run so im thinking someting is up with a gaskett. Cause now when i start her she blows white smoke and just smells a little of fuel so coolant is what im guessing she is parked now and all the plugs had a little carbon on them from best i could tell where it is black it Doesnt come off and isnt wet. Before i replaced all the intake valves from umbrellas to felpros they were all pretty sooty. Well anyhow check this link if you want more data from that
day at the track.
http://www.turbobuick.com/forums/general-turbo-buick-tech/303877-another-knock-logger-attached.html
Hi Justamatt,
Sorry about this problem but, I and many others have been there, it's a truly sickning feeling. Hey, I left 8K layin on the floor of a speed shop once doin a dyno run because the crank broke at about 6K. Motor was a total lose, block and all.
Your discription of the problem indicates you are getting coolant into 1 or more cylinders but I think you know that. You don't need to be a NASCAR crew chief to look at the plugs again to see which one or ones are really clean, the clean one is where the water is. I personally hate doing this but, you need to pull your heads. If you haven't had any head work done it's probably not a water jacket issue but stranger things have happened so get the heads pressure checked, this is not an option, do it! Now you should be able to see where the head gasket failed, hopefully that's the problem, the cylinder or ders will be steam cleaned on the piston top. I'm thinking that this is the problem but even if it's not, I will give a personal opinion and choice here, get some stock size cometic gaskets and a can of gasgacinch, apply librally to both sides of the gaskets and follow the torque sequence in 3 steps. OK! Now for the really bad scenario, you had a rebuild done. There is a possibilty that the cylinder work cut a water jacket to thin and has broken thru. If the heads and gaskets check out ok you will need to pull the block strip it down and have the cylinders sonic tested. I haven't seen this happen but I know it's a real possibilty. As a rule, machine shops normally check for this so I have to say it's a very, very small chance.
