Drove the car to work this morning. Mega super duper homemade catchcan is doing the trick. Doesnt run that great at idle and has no power under boost (no codes popped up, all scanmaster numbers good) but drove 35 miles. Got to work n popped the hood cause I saw drops of oil under the car on the ground, looked underneath and fresh engine oil was all over the tranny pan and tranny mount bar...so I popped the hood and oil is seeping out of the lower head bolts on the drivers side. I saw this yesterday and assumed it was the valve cover gasket, but I popped the valve cover off yesterday and all is good. No leaks...they're brand new anyway. Siliconed them up for kicks. You look at each lower head bolt and there is oil leaking out from under each bolt head. How is this possible? I sealed every bolt up when I got it back together, and regardless, they run through a water jacket, not oil.
