Is it possible in any way for the oil pump gears to develop any play, in any direction, or make noise?
I've always had the unknown knocking noise that the car has had and been thrashed a little here and there with for almost 3 years now. It was very faint when I first got it, so I blamed the cam sensor. The noise got a little louder, so I finally replaced the cam sensor (whole assembly) with a brand new GM unit. This made a whole new different noise of its own, which quiets up after the engine warms up. But now I'm starting to wonder why.
The knocking noise is getting a little louder here recently, and I've been having some new issues with false knock / timing retard in copious amounts on certain conditions, and wondering if its related to this noise.
Under engine acceleration, it does not make a sound. Once I let go of the throttle and let it decellerate, as it passes back through the lower RPM's. If I bring the RPMs up a little and hold the throttle at a certain point, it will make this sound and remain consistant until I let it go again. I just changed the oil and started running 20w-50 for the warmer weather, and it seems a little louder, and it even does it a little while just idling.
Upon listening and poking all over the place with a stethoscope, I get a little of it from the top of the cam sensor still. But when I touched the stethoscope to something I never checked before, it was pronounced a bit more... the oil filter.
Then touching it to the oil pump housing area, I seem to hear it the most there. It's not quite as loud through the stethoscope as I would think it would be though, being that the noise is pretty damn loud just standing there listening with the hood up.
The cam sensor is still the new replaced one, and I almost switched the old one back in at one time to see if it was quieter then the new one, but I didnt.
Anyone think the oil pump might be a possibility?
