F FLGN Member Joined Jun 22, 2009 Jul 20, 2009 #1 What is the easiest way to hook up a temporary mechanical oil pressure gauge?
H Heg87t Slightly Compressed User Joined Mar 18, 2006 Jul 20, 2009 #2 I have an inexpensive gage under the hood on my car. I hooked it up when I broke my engine in so I could see it under the hood. I put a piece of pipe and a second tee into the stock tee that feed the turbo and has the oil pressure sensor.
F FLGN Member Joined Jun 22, 2009 Jul 20, 2009 #3 So you put a T fitting in where the turbo oil feed line is now? Where can you get the fitting and what size are they? Thanks.
H Heg87t Slightly Compressed User Joined Mar 18, 2006 Jul 21, 2009 #4 Hey, I will have to go take a look at what I have not to give you more specifics. My memory is not that good. I will try to get you more info tonight.
J Just a Six?? OK! Who Farted?? Joined Jul 4, 2003 Jul 21, 2009 #5 There are some good pics of mine on Vortex Turbo Buick Performance Also a writeup Steve did to explain it all.
