op gasket
Hi,
I had problems with my TType leaking after I did a rear seal replacement, and I'm pretty sure it was the pan gasket at fault, not the lip seal. I used the OE silicone rubber Felpro, have since bought the thick cork Duttweiler replacement, which I will install when my rebuild is complete. Sorry I can't tell you how this will work, but I understand a lot tighter seal is provided by the cork.Of course, it is a lot easier to do a clean installation with the engine out and on a stand. I hope you resolve the problem, because I understand how annoying leaks are! Good luck....
