So I dropped the tank today to install new fuel lines (just the ones from the frame to the tank). I installed the tank and the car ran in idle and I gave it some gas and it revved up real nice, then it completely cut out.
I went to the back of the car noticed the pigtail connecting to the tank was not connected, so I plugged it in, and started the car up, now it ran like crap, so then I went to the back of the car and disconnected the pig tail, and the car started running real well again...and then cut out (I assume because it was no longer getting gas because the pump was no longer running)
So my question is this, what could be causing the car to run terribly when the pump is on, but smoothly when the pump is off just before there is no more residual gas left in the lines.....I assume it is some sort of electrical issue causing the pump to draw to much power???
Any advice would be great!!
Thanks in advance.
Thanks in advance.
