I have the negative side of the relay wired to the ECU
I have 12v wired to battery
I have 12v switched to my arming switch
I have the wre hooked to my NOS solenoid from relay
I have 12v switched to the other wire on the ECU
WHy is it that when I hit the arming button that it sprays?
It seems as though the Fast is constantly grounding the relay its not waiting to hit my parameters.
with the car off and the key on it sprays.
I cut the solenoid wire and took the car to the parameters and it dumped the fuel set per the parameters, but the NOS is activated per the arming switch which I know is wrong.
Is there something wrong with my FAST ecu that its constantly grounding the relay when it should only ground it when it hits the parameters.
Rob
Rob
