R rb68rr Active Member Joined May 25, 2001 Feb 5, 2012 #1 With key on I have no radio or power windows or anything! The headlights are on and bright. However when i turn the key to try and start it I don't get anything! The headlights don't even dim while trying this! What's going on? Thanks, R.B.
G GNVenom Well-Known Member Joined Jan 6, 2002 Feb 5, 2012 #2 1. Battery cables 2. Battery 3. Don't forget to remove the delay relay from your engine bay.
J ~JM~ Wrinkled Member Joined Oct 31, 2007 Feb 5, 2012 #3 Check your cables are clean & tight on both ends. Check your grounds. Good luck ~JM~
