Just to catch everyone up..car would crank and run fine until it warmed up and would start missing and eventually shut down, not cranking until cooled down. First thing I did was change plugs, wires and coil pack. Well, I didn't get one of the connectors up and it shorted out causing modules clay to become like chewing gum..not good.
Well since then, I have replaced the module and fuel pump relay (probably the problem in the first place--found relay particially melted) and car absolutely has no fire.
Just to verify things I need to check, and any clues that you could give me in checking these things.
Fuse (under the dash, is there another location?)
Crank Sensor (spin car over and see if I got a RPM reading?)
Cam Sensor
*fuel pump relay, found where it had gotten to hot. Is it possible that relay just went bad, or could fuel pump be shot. Walbro fuel pump has less than 5k miles on it which I know means nothing this day in time.
Cam Sensor
