my 200 4 R won't shift into 3rd gear when the shifter is is put into 3rd. Shifts 1-2 ok, just won't go into 3rd. Seems to go into 3rd when manually shifted into overdrive (not sure if I'm getting 4th or 3rd)
Transmission was just rebuilt with a regular valve body. Didn't have 3rd gear from the get-go upon installation. I thought it was the valve body/governor so we took a "known to be good"
GN valve body and governor and installed it. Worked fine on road test.
Towed the car 600 miles to race. First run, worked fine. Second run, wouldn't shift into 3rd. Towed back home.
Transmission has the usual build stuff: kevlar band, kolene steels, 10 vane pump, trans-go shift kit, super servo, Stage-rite TB, 9" art Carr N/L converter (3500 stall).
Any help from trans gurus would be appreciated
