Few ?'s.
Do you have an oil pressure gauge?
How far down did you tear the motor? Bare block?
If so, did you remove the plugs in the oil passages by the cam?
If so, did you peen the plugs after install?
This happens all the time, guys put new plugs in and forget to peen them and when started the oil pressure pushes them out. If this happens, you now have a 1/2 oil passage lubing your timing chain and nothing in your top end. No oil pressure either.
If you did not remove the plugs, this is not your issue, but I just thought I would mention it. It has come up on several other forums I belong to in the past.
Hope you find it,
Coach
