Hello all. I'm still monkeying with my newly installed SMC kit, and am trying to settle on a nice comfortable boost level for my mostly stock setup. Just the other day (80° ambient or so) I had 4 or 5 "digs" recorded on DirectScan. No knock whatsoever at a steady 20 lbs of boost. Alky on at about 13 psi (can't tell for sure) and pump speed at about 5.5. The car felt great...and no visible problems. So of course that means I'm not running her hard enough, right?
Anyway, so I take the wastegate rod in another 1.5 turns (shooting for 21.5 psi or so). Tested her again heading up a bridge on-ramp. I got 4° of knock or so through the end of 2nd and all of 3rd gear (only took her to 70 or so...in a 35 zone). I thought maybe the hill did something, so I would try again.
Same boost setting (21+ pretty steady, up to 23 or so on the shifts), but the air had gotten a little cooler (70° or a little less). Nice straight shot in the north end of town. I ran her from a dig up to 90 or so. I had HUGE amounts of knock, up to 9° in 3rd gear, and several degrees in the lower gears (which I almost never get).
So, my question is, WTF happened? Is that a typical jump for just 1-1.5 psi of boost? I thought the idea of sneaking up was to avoid any big knock numbers. 9° scared me. Could the cooler air have done anything? Did my kit just not fire on that run? (didn't see the light, I was busy watching the road). While tuning I am running a 10-15% mix of Xylene with my normal 93. So about 96 octane, just for insurance (which it looks like I needed here).
Help! Just trying to figure out the score. After the rain today I'll put in another gal of Xylene and try it out. Thanks a LOT!!!
