MNcarbturbo
What's Fuel Injection?
- Mar 9, 2009
Bought a BY code 200 4R that I was told good. It didnt have a converter so I bought a used D5. I put it in the car and it isnt pulling any fluid. I had the pan off and changed the filter so it was pretty much empty. Fluid and filter were nice and clean. I put maybe 4-5 quarts in and the trans is full. Started the car and it doesnt move. There is no fluid flow out of the trans cooler lines and the fluid level hasnt gone down any. Converter is clearly seated since I pulled the converter bolts out and turned it, can hear a bit of sloshing in the converter and it goes all the way back. Ive read it should take 5 quarts or something, but my converter and cooler lines were sorta dry so it should take 7-8 im guessing.
Im assuming something is wrong in the pump. What breaks/happens so that there is no pump flow?
