I am told a 9.9 and double pumpers with stock lines is possible
Steve went 9.50s with double pumper and stock lines.
Changed my mind again. Started doing the fuel system tonight. Its going to be cheaper for me to go to my race with e85 and a new feed line then buying race gas.
First thing I did was added another 3/8ths line to the stock fuel sending unit. I'm going to t the pumps outside the tank now. I ordered some fittings for this setup: I'm running 2 3/8ths hoses to -8 to 3/8ths barbed fittings that tie into a y fitting that has 2 -8s to one -10. Going to a jegs 9" filter with a 40 micron ss element. Then continuing a -10 to the stock fuel rail. For the return, I have a -6 outlet for the regulator. I'm going to run a -6 line to the stock feed, reverse filter, then back to the tank.
I'm going to see if that return will let me run both pumps all the time. I used to run a double pumper like That with a normal -6 return and never had issues. Should have all this done in time when the converter comes back.
Compression fittings... I don't like compression fittings. Especially on a fuel line.
You're killing me! NOT ON BRAKE LINES!Just a temp fix until I can run a new return. Besides, it is the return which shouldn't have too much pressure. Have you run into issues before? I've seen them on brake lines which would be way higher pressure than the fuel system.
Using compression fittings on transmission cooler lines will usually result in leaks 50% of the time. The leak could be very minor, but a leak non the less.
If you want a 100% dependable connection, use a double flare, or AN fitting.
