bought a new pm pump /motor assembly from oldbuickparts . i already had new pressure sw and acc laying around. i installed it and noticed motor would not shut off so i found out that u have to disconnect line under acc ball to gravity bleed so i did and found an o ringed valve was in there to and dont know if it will bleed with that thing in there or do u take out . anyway , tightened nut assembly back up and pump did finally shut off. drove about 100 miles and brakes were great but light started to come on and pulled cover and fluid was really high. but brakes continued to be great all the way home. but i know somethings not right and now motor wants to run over 30 secs. before it stops and then every 15 secs it recycles and does the same thing . you can see passenger side level drop and come back up constantly, but im assuming some kind of additional bleeding is necessary. i dont think i have any bad parts . do i have to bleed the grey master cyl. itself .Do i disconnect the 3 lines on driver side and gravity bleed , if so for how long and do i have to rebleed at the wheels after i do this. i read over gnttype.org tech articles. i just need a little more guidance in laymans terms . i hope someone has recently done this and can remember the details. i absolutley want to keep my pm . i just laid out lots of $ and going to OC cruise in 2 weeks. just want to get it fixed right.
