stagemonster
R.C. entourage
- Jan 16, 2005
Well iam hope i get service like that id like to drive it this summer sometime.
The only other guy i know that has ****tier luck than me is Bryan...........
Have you seen my latest thread?
http://www.turbobuick.com/forums/en...ews-upon-pulling-motor-today.html#post2790127
Bryan
I totally undserstnd what you have gone thru.
Me and RC built my stroker motor and had the cam sensor break and resync itself in the water box(BG 2010) and it popped very hard and came to grinding halt. So i repaired the sensor and motor ran fine till it lost oil pressure. so out it comes again.....
A few months later I got it all repaired, ( had to get crank reground/polished).
I reinstalled it and all was well until about 500 miles into the break in i got that same low end rattling noise.
So out came the engine again.. ( now this is the third time in less than a yr) the #4 main bearing an #6 rod bearing had a bunch of metal embedded in the bearings. ( the Rod bearing had also lost it's crush and fell out of the rod cap) the crank survived with no damage thank goodness
The metal came from me being a idoit and thinking that the oil cooler was filtered oil. so the engine got a bath and reassembled.
So that was a couple of weeks before the TB.com nats. So far it has about 1500 miles on it and is all good.
I reallize that this does nothing ot the OP but i thought i would add my 2 cents lol.
Take it back to the engine shop and have them fix it. I hope that you don't use the oil cooler again after having a engine failure..
Called and waiting on a call back.
ouch!!! i feel you man. that sucks because they never have to do the dirty work of install and removal. they got the easy clean work. that happened to me on my 1970 442 w-30 never made the cam break in. good luck on getting this straightened out
What rod bolts are in there? Looks like stockers.
Did you change converters?
Billy T.
gnxtc2@aol.com
