Thanks.
The scanmaster is being delivered tomorrow so I can adjust TPS and IACV to specs, idles rough now. I'll wait until I get the new chip to tune everything else.
I ordered 6 AC Delco CR43TS plugs, AC Delco transmission filter and gasket kit, AC Delco locking gas cap and a couple oil filters. Also ordered the rear seat brace from kirban, battery hold down, plastic flywheel cover(was missing), kyb excel-g shocks and other stuff I can't remember.
While waiting for parts to be delivered I removed the aftermarket radio and wiring, cleaned the throttle body, and installed the correct battery side terminal bolts. Plan to bleed the brakes tomorrow, under the dash, remove some crip connections then solder and heatshrink.
There is a narrow band autometer gauge in the a pillar pod gauge pod and the signal wire is already in the engine bay. Is it worth hooking up or should I install a wideband? Not planning on doing any performance modifications for another year.
