national84
Heavy breather
- Jun 21, 2001
For $575 you send us your intake,86-87 plenum, and 86-87 Tb, we will send you a modified intake, plenum, modify your TB, and send it back to you. Your intake will return to you with a pipe made to go from turbo to intake. We will also make up a custom block to make your iac controller remote mount.
The list we have posted iss truly complete. The only piece I see that we neglected to list is the 86-87 throttle/tv bracket. But finding those shouldn't be too much trouble.
You will need gaskets obviously, but the 86-87 units will work for the plenum/tb/intake.
We have a guy working on an instruction sheet, which we will probably post here to make things easier.
I assure you there are no hidden costs here, that is what has taken us so long, we wanted this to be as bolt-on as possible.
Serious inquiries can email me at Mhardman6@insightbb.com I will be glad to give you my phone number to discuss full details.
I forgot to mention, due to the number of different turbo's available, we cannot supply a silicone hose from turbo to the tube that goes to the intake, so you'll need to get one of those yourself. The pipe is 2.5" od mandrel, so 86-87 turbos need to neck up, stock hotair turbo's neck down, pte turbos ....and so on.
