Just got a new set of GN1 SE headers to replace the cracked DS stocker. After much deliberation I settled on these as I didn't want to keep pulling and repairing the stock one. Anyway, the headers look somewhat ok, after they get up here they're pretty much $800 bucks, so I use the term ok loosely.
My problem/question is, the flange on passenger side is warped 1/8th when a ruler is held across it, driver side is warped a bit but not as much, is this standard fare for these type of headers?. I'm a little worried but I figure it would be more important that the port flange mating surface is flat. Also they will not fit because the top of the flange hits the valve covers -so I guess grinding is in order. I had to loosen the Turbo bracket to get a little wiggle room/mate up -I'm a little worried about that too.
I should also add that the supplied gaskets are a terrible match so I think I will go with Permatex copper.
