Details of the run:
60'---- 1.680
330'----4.745
1/8---7.264
MPH---99.48
1000'---9.443
1/4---11.249
MPH---122.00
Screen Name or Car Number Here Razor
EMPTY WEIGHT:?
BLOCK:stock
HEADS:TTA fully ported
CAM:Reed 210/205
TRANSMISSION:sorta stock
TORQUE CONVERTER:9x11 3600 billet L/U
DIFFERENTIAL:stock
INTERCOOLER:front mount
THROTTLE BODY:stock
RJC POWER PLATE:Yes
INJECTORS:50#
THERMOSTAT:160
TURBOCHARGER:TE67
VALVE SPRINGS:100lb
MAF:none
DOWN PIPE:3"Terry Houston
EXHAUST:stock w/cutout
FUEL PUMP:Walboro 307 shimmed
FUEL PRESSURE REGULATOR:billet Adj.
FUEL PRESSURE:42
ALCHOHOL INJECTION:YUP
PROPAIN INJECTION:No
NITROUS:No
AIR FILTER AND AIR INTAKE:K&N
TIRE DESIGN, SIZE & AIR PRESSURE:M/T ET Streets 11.5x26x16 @13 psi
AIR BAG(s):yes
SUSPENSION:stock
SCAN TOOL:Scan Master II
FUEL:93 BP
CHIP:Max Effort ME-r
CHIP TIMING:18 + Spark translator
KNOCK RETARD:Zero
OXYGEN SENSOR VOLTAGE:760's over the line
EXHAUST GAS TEMPERATURE:1620
TRACK ELEVATION:10ft ?
TEMPERATURE:90+ degrees
PEAK BOOST:24 psi
BOOST AT LAUNCH:3 psi
MILES ON THE CAR/ENGINE:29K
I run a Greddy ProfecB specII boost controller.
Todays I ran the car progressively faster. Runs were 11.890, 11.531, 11.475, 11.383, then the 11.249. Thanks to the words of my friend Roy Garcia.. start off slow.. work your way up.. The first pass I red lighted and didnt launch(seat time)
First runs converter not locked. Last run it was locked
