Hello,
I own a GMC Syclone, not a GN, but I would hope someone here could help me as there isn't much knowledge in the Sy/Ty forum about the BstC Boost Command.
Here's a little background to understand my combination better.
GMC Syclone
BstC Boost Command using Map Signal instead of TPS for the primary trigger. (The Syclone doesn't use a MAF)
PT&E TE-44 and 3" Downpipe w/ internal wastegate
RaceProveMotors A2A kit
Ultimate chip
Stock 28 lb injectors
Aquamist Water Injection
HHP Racing 700R4
12.195@110 mph (This was done with the stock air to water IC)
Anyway, I was able to get decent boost control w/ the BstC with the stock air to water ic, but I recently converted over to a A2A sytem and I can't seem to get anything less than 19-20 psi with the primary control knob turned all the way down! This A2A setup flows big time air!
I have the #1 and #2 back switches in the off position and the #3 and #4 switches in the on position. Red light on front of BstC activates at 4 lbs of boost. Wastegate rod is set to 15 psi. Turbo compressor hose is connected to metal nipple on AC Delco Solenoid and wastegate actuator hose is connected to the plastic nipple above the bleeder nipple on the opposite side of the solenoid.
Any ideas on why my BstC isn't getting the job done?
Any help would be appreciated.
Thanks.
Adam Auerbach
Sy #2419
GMC Syclone
Ultimate chip
HHP Racing 700R4
Thanks.
Adam Auerbach
Sy #2419
