I have had alky for awhile, running ~23# of boost. Recently, the ground and pump became loose causing the alky to not function properly. I thought I fixed the problem so I set the boost to 20#. I took it out and everything seemed to be fine part throttle and 3/4 throttle. So decide to go WOT. When I went WOT the alky came on and I reached 20# but right before it was going to shift it sounded like my up pipe blew off or louder. Immediately pulled off and saw nothing out of the ordinary no smoke, coolant, or oil anywhere. I was watching the scanmaster while this happened and saw no knock retard? What would have caused this?
