martymcsuperfly
- May 14, 2007
HI Guys,
I thought that setting the TPS was well with in range of abilities. however, I cant seem to get it right. Which wires do I check? Also, I assumed it would be the same wires for WOT. Last night when I tried this, I couldnt get close to the .47 volts. I had to change the sensor. After that, I was able to get to the .47. however, then I couldnt get more then 3 volts at WOT. I am having a rough time getting this car to idle correctly. When started, it just jumps right to around 3k and pretty much stays there for a while. Thanks guys! its been 7 years since I have owned one of these things. So I have forgotten all but how sensitive that they really are!
