mikestertwo
- Sep 13, 2006
I have the .44 volts at the TPS, but at WOT the highest it goes is 3.05 volts! Is there a way to adjust the wot volts without messing up the .44?
Also, with my cam sensor, I cant get that thing anywhere near the volts it should have. It will only read 5 volts!
Make sure the mat isn't under the gas pedal.
As far as the voltage on the cam sensor, I could just be your battery is a little low.
