Pete Revenidis
- Mar 31, 2013
I remember my brother in law having to port the waste gate in hi GN back in the 90'sday he had same problem is there a post on here on how to do it with pictures
It may be a HD actuator that runs at a nimimum of 18 PSI. A stock one should allow you to turn it down to 12
The wastegate dumps into the same pipe as the exhausts that passes through the turbine. If the (restriction) theory is correct the wastegate should flow better when uncorked as well. Some things don't add up....
All I can say to this is that I switched from the stock downpipe, test pipe, and exhaust (including stock muffler) to the 3" THDP, test pipe, and ATR 2.5" exhaust back when I was running the stock boost control. When I got done, my boost went up several psi with no other changes, even though both the turbine and the wastegate were both "flowing better". Others have had similar experiences when using the stock boost control and doing something the lowered back pressure behind the turbo. Since the OP is essentially doing the same thing (significantly lowering back pressure behind the turbo when he opens his dump), and he is running a similar turbo (TE44 vs. my TA49), I'm not surprised he's getting a similar increase in boost. Admittedly, going from 15 psi to 21 psi is more than I would have expected. But, the only thing he is changing is the exhaust system behind the turbo, so what else could cause the boost to change when he opens his dump? Maybe I'm dumb, but I can't think of anything obvious.
Come to think of it, I was running an un-ported wastegate when I had the stock exhaust system. When I put the freer-flowing stuff on, I had bad boost creep that I could not fix by changing the stock wastegate duty cycle % in the chip (I burn my own chips). I had to port the wastegate hole to keep boost steady at around 17 psi as RPM's went up. This makes me think that freer flowing exhaust "helps" the turbine flow much more than helping the wastegate flow, for whatever reason.
