Need help with modified ecm
tysongross
Mississippi Mayhem
My ecm was modified for peak and hold injectors. Today i noticed the powerlogger was loose so I pushed it back in while the key was turned on... I saw a little smoke come out near the powerlogger board connection to the ecm. Now the car will not start it will fire the immedialy die. Is there anyone that can replace the ecm that has been modified?Im thinking its toast since the smoke came out of it. Thanks
Yea you have to trap the secret smoke inside jk lol I'm looking for one as well . I emailed Bob Bailey and hopefully he will be modding some soon .
Check to make sure the analog cable is plugged in the powerlogger and analog block.
Why speculate? He smoked it mucking around in there with the key on.
Sent from my iPhone 6+ using Tapatalk.[emoji252]
I always try and look beyond the actual question and pick out clues. If the ecm fried I don't see the car starting. More troubleshooting need to be done IMO.
I would connect to the pl with laptop and see what you see.
