Had the car (87 GN) running just fine 1 week ago, went to crank up yesterday and no fuel pressure, no pump running. Started running some checks, I do have a hot wire kit, and from the stock harness going into the Hotwire harness, I am only getting 7 volts and that isn't enough to trigger the Hotwire kit relay. I did jump 12 volts to the Hotwire relay and pump runs and car runs fine. 7 volts switches on/off with key on/off ignition, so that tells me that the fuse and relays are actually working but I can't seem to figure out why I'm not getting enough voltage , I've cleaned the fuse and relay contacts, checked grounds. I'm baffled, as I can diagnose a no voltage issue but lost on a low voltage one.
Any help is appreciated!
Brandon
Brandon
