Well, my brakes were working fine except the light would come on every now or then, so i purchased a accumulator ball from kirbans that was tested good.
Flushed the system and cleaned out the brake reservoir bowl. put in new fluid.
Then followed the steps on here to bleed the accumulator, deppresurize, turn key key doing till no bubbles etc. then i bled the master cyclinder with disconnecting the two lines and connecting the plastic ones and rerouting the hoses back into the resovoir. I had my assistant keep pumping until no air bubbles present. Then i proceeded to bleed all four brakes. No air anywhere
Brakes are hard, turn on key brakes still hard, start car brakes go to the floor and the brake light comes on. I did this procedure 3 times now. The brakes were not even close to being like this before i started. Anyone know what im doing wrong ?
i followed the procedure from zeus
http://www.turbobuick.com/forums/br...ls/218912-powermaster-bleeding-procedure.html
