Ive run turned drums in my car over 700 ft lbs with no problems. Probably thousands of ratio changes under high torque. Taking .005-.010 off a direct drum is not a problem as long as the drum is not wavy after its cut. Ive used turned drums over 20 times with no problems in TR's that ran faster than 12.50 in the quarter. I doubt you will have a problem if you have a competent machinist turn one for you. They get warped and heat checked when they werent set up right form the beginning. Alto red wide band, proper servo, proper band clearance ,and line pressure will keep it going strong for a long time. Replace the 2 bushings in the drum also. If they are worn the drum will not be central when the band applies causing slippage and band failure.
