My first passes
mapmaker
The 2013 Buick vs Ford event at Noble was my first outing to the track. First run was way less than I expected - 12.78 / 108 with an awesome 1.972 60' :eek:. Made a total of ten runs for the weekend, finally making my best past the last time. Between each run reviewed PL and adjusted boost, timing and fueling. Boost is creeping on the top end from about 24lbs up to 28. Needless to say the launch needs work.
60-1 w/stage 3 billet wheel, alky, 50lb injectors, RJC 3"DP, power plate, & boost controller, LS1 MAF w/trans, PLX WB, Turbotweak 6.1, test pipe, Pypes Race Pro Duals, 295/55/15 MT ET's, boxed upper & lower rear arms, air bags, EGR delete. 3,600lbs w/driver
24mph out the back is good. Keep working on those 60's and you'll be amazed what it does for the ET.
