Ron Coleman
- Jul 17, 2005
i have this problem for a while. it raises when i accel and stays in that range untill i let off the gas and go at a lower speed and then it goes down to about 122-128 range....it's like if i keep it at a lower speed it stays below the 128..i go wide open and no knock o2's in the 820-830 range at 16 ponds of boost...anyone know what it could be?? im going through gas like crazy!!
this is what i changed so far:
o2 sensor new delco
fuel filter
fuel sock
fuel pump
injectors from 50ilbs to 36ilbs
fuel regulator
pvc valve
put gaskets on the headers
new iac valve with gasket (i was reaching for anything here)
i sprayed all the vacuum lines and nothing because i thought i had a leak.....
the only thing i didn't change is the maf (maf is 5-6 idle) and plugs and wires
the thing is the bl's stay in the 125-128 range at idle
o2 sensor new delco
fuel filter
fuel sock
fuel pump
fuel regulator
pvc valve
