Moser axles installation
Onalky87
Installing these in a week or so. Anything I need to know? Or is it just pull dif cover and c clips and pull it out
Pull the cover, unscrew the center pin bolt, pull the pin, push the axles in to unseat the c-clips, pull axles out. Reverse.
Use a mag pickup to to ease c clip removal. Replace axle bearings and seals as well.
ditto on the magnet, and reinstall the pin if you will not immediately be putting the axles back in, do not rotate anything with the cross shaft out !
Put Mosers in my car last spring. I went ahead and replaced the bearings/seals as well. Rent a slide hammer from Autozone to pull the bearings, makes it very simple. Make sure to use a new cross pin bolt, do not re-use the ones that comes out (if it comes out in one piece). Use Dorman 81048, only $1.39 @ RockAuto.
So other then the axles themselves. What else do I need to buy and where do I get it? Like bearings,seals etc
What else other than the axles themselves do I need to buy and from where. Like bearing,seals etc etc
Glad to see you on Fred. How's things going now?
As far as fluid synthetic works fine but I still prefer lucas and the GM posi additive.;)
Hey Charlie. Not to bad just tryin to get her ready for spring. Just got my trans back from Lonnie
So far this is what I have .... I'm not sure what u guys mean when u say replace pin. Can u post links to everything ill need? R these things I can get from a parts store so I don't need to order?
http://www.gbodyparts.com/product_i...d=748&osCsid=86c50d468448d7bd297c12b6eac1c71a
http://www.gbodyparts.com/product_i...=1196&osCsid=86c50d468448d7bd297c12b6eac1c71a
Sent from my iPhone using Turbo Buick
