I got my oil pump primed the other day and today I attempted to set my cam sensor. I realized that I do not have the bolt that holds the cam sensor in place. Does anyone know if this is a special bolt? I saw in one of the diagrams that it is a bolt and a large washer. I don't really see how this holds the cam sensor, but does anyone have the dimensions of the bolt and washer? I seemed to have lost mine.
I then tried to start the car, and still nothing. It seems as if the injectors aren't firing because I have 40 PSI at the rail. My friend pulled the injector harness and when we did it we heard the fuel pump go on and a relay clicking on the passenger side. We're guessing wires are grounding out in the main engine wiring harness causing the injectors to not fire? Does this sound right? Should I disconnect the coil pack and see if I can get back there to see if any wires are exposed? Any suggestions/tips/help is greatly appreciated.
Thanks.
Thanks.
