This is the problem on my brother's GN that we can't figure out. On a roll on kick down at about 40 mph, the car gets 58-60 kr and the o2 are 68 to 65. As he keeps the car floored the kr start to go away, but on the initial shot the kr are very high. When he floors the car it feels as if the car doesn't wan't to take off and gives these little shots and when it shifts to third the car pulls great. The tranny has been rebuilt but could the torque convertor cause this type of problem? The fact the car is running lean I really can't figure it out, he put a new walbro fuel pump with 60lbs motron injectors calibrated with a 93 and 100 armstrong chips and hot wire kit, smc 100% methanol injection adjusted to max pump speed, and 20 to 21 lbs of boost.
Help will be greatly appreciated, thanks we are really puzzled.
Marco.
My brother’s 87 Grand National t-top (92 000 km)
Stock block with trw pistons and 30 over, stock heads, 210-205 lunati cam, PT61 Turbo, 65 mm kenne bell TB and plenum, 9 inch 3000-3200 stall art carr convertor, 22 ½ boost, 94 octane with 100% methanol with smc alk injection, thdp, hooker 2 ½ exhaust, 60 lbs motron injectors, Armstrong 100 chip, ESP front mount IC, 26 BY 10 M/T ET STREEET TIRES, 3800 LBS race weight.
BEST ET= 1.60 60FT- 7.47 1/8- 11.80 ET-113 MPH
BEST MPH= 1.72 60FT – 11.87 ET AT 114,74 MPH
Marco.
