slow 86 gn
Still SLOW
- Feb 12, 2002
Checked for air leaks could not find any. Here is how the car is running. These numbers are off of turbo link. MAS AIR 4G/S IAC 21 LV8 36 TPS .43 O2 CC 16 INT 124 BLM 110 MAT 72.7 PROM 1966 COOLANT TEMP 167 RPM 725 BATTERY VOLTAGE 13.8 CLOSED LOOP. The problem is it is still running rich. The only thing that I could think of is the manifold gasket mite have blown out to the inside of the motor. The heads were ported quite a bit, and there is not much for the gasket to grab .080 or so. Any help is appreciated. Thanks for the HELP. John
