T tta1240 CAMEL TOE Joined May 5, 2003 Mar 23, 2013 #1 im just wondering if anyone has put a 85mm z06 maf sensor in there up pipe.if so how did it run?
E earlbrown runs with scissors Joined May 26, 2001 Mar 24, 2013 #2 I believe you have to reburn the chip to work with an uppipe mounted MAF as the temps and pressure is much greater.
R Roger Active Member Joined Jun 1, 2001 Mar 24, 2013 #3 It has been done with good results. Pushing air thru a MAF is more efficient than pulling air from it. Do a search, was on this board a while ago.
R RmvBfrFlght Well-Known Member Joined Sep 28, 2007 Mar 24, 2013 #4 Bruce (rip) has a write up and the gnttype tech section. RemoveBeforeFlight
