G Granny 2 New Member Joined Jun 19, 2001 May 23, 2002 #1 I would like to hook up a low speed fan switch inside the car. Which wire do I tap into. I know the hi speed is the green wire below the throttle body. Thanx
S Steve Wood Active Member Joined Jul 18, 2001 May 24, 2002 #4 ground the dark green wire off the relay....That's the low speed side. The High speed relay has the dark green with yellow stripe.
G Granny 2 New Member Joined Jun 19, 2001 May 25, 2002 #5 Thanks Steve, did it today and it works perfect. You da man
