Sleeper1987
3.8L of Fun!
- Jun 11, 2006
got about 7-9 psi hot idle pressure 15w40 shell rotella and 10 psi per thou till i run it down the interstate for a while then it creeps down to 20 psi at 3,000 rpm. I installed a new oil pump gearset and had the adapter surface cleaned up so the was no grooves. Added the 70 psi spring in the melling kit, tryed the 60 and the 40 psi springs with no differance. It has the biggie oil filter kit with the large diesel suburban filter and long oil lines to a mount in the old battery location. they have a 5/16 oil line ran to the turbo from the oil filter mount. i added a .080 restrictor to it with no pressure change.
so heres the basic rundown
oil has about 200 miles since changed 15w40 shell rotella
ac delco oil filter on remote mount 3/4 oil lines to and from
new oil pump gears and gasket
new relief spring.
no smoke rattles or knocks.
7-9 psi hot at idle
around 20 psi @3,000
can free rev it and it has 10 psi per 1,000 but not with load.
Any ideas? maybe go back to a stock filter?
new relief spring.
7-9 psi hot at idle
