Hi guys,
I recently picked up a totally stock 87 GN with 65,000 miles. I did a full spring cleaning as suggested on gnttype.org. Car runs significantly better, but after getting my scanmaster hooked up, it looks VERY lean, and I'm getting 8-9 degrees of knock at WOT. I know that is bad news. Stock boost levels, stock chip, upgraded fuel pump, adjustable regulator, K&N, stock style exhaust (has been replaced recently though). New o2 sensor, new plugs, wires, cleaned intercooler, all vacuum hoses replaced, header crack welded up, I suspect the aftermarket stock style MAF that was replaced at some time may be the culprit. I had to crank the fuel pressure up to 46 line-off to get it running well, It still acts lean at WOT though. I hooked up a good fuel pressure gauge and watched it at WOT, pressure held steady at 65ish
IDLE:
BLM 150
INT 150
TPS .44
IAC 34
AF 3-4
02 50-850
idle 625
coolant 190
WOT:
O2s start around 780's and dropping
knock gets worse, so it isn't false
AF 174 initially, then dropped to 140s, slowly climbing
driving around BLM around 128 and Int jumps 120s to 140s
Any suggestions? Anybody in Austin with a good MAF I can try?
Any help greatly appreciated
IDLE:
BLM 150
INT 150
TPS .44
IAC 34
AF 3-4
02 50-850
idle 625
coolant 190
WOT:
