Hey fellas , my gn used to push 16-18 psi, now all of a sudden it barley makes 10 psi, i did not make any changes to my car, it just happend all of a sudden, i found a crack on my DS exhaust manifold and just had it removed, welded and put back together with a remflex gasket, i was almost 100% sure that was were my lost boost was going..i checked turbines for any play and oil in my intercooler, all is good, i tried looking for a crack on the pass side manifold, but could not visually see a crack from looking top of motor down , my blm's read 137 then somtimes when i shut it down and restart, my blm will read 128, & somtimes under, car idles fine and runs pretty much decent, except i can notice the slight loss in power at wot....any suggestions
Iac-13
Tps-44
Rpm-650
Bat-13.4
Iac-13
Tps-44
Rpm-650
Bat-13.4
