I agree with you guys about the proper tools and that you can (many people have) go deep into the 11's on the stock injectors. IMHO, it is not as "safe" as using some bigger injectors. The stockers go over 100% duty cycle with the stock turbo. This is far from ideal. Alky does help. If you stick with the rule of thumb to keep duty cycle 80% or less, then the stock injectors are a bad idea. Can you use them.... sure. If you have to go out and purchase a set of new injectors, I am a big fan of the 60's unless your goal (now or in the forseeable future) is faster than mid 10's. IMHO, the 60's drive better and idle better than the stockers did.
If you are really going to do some tuning, I recommend a power logger and a wideband.... and a TT wideband chip. Makes things alot easier.
