Nevermind guys I readjusted mine and all is well....I would highly recommend everyone experiencing misses and backfires that don't seem to be ignition related try setting #1 to tdc and just slightly rotate the cam sensor counter clockwise to further it into the "window" the sensor operates in...I had mine set to right when the voltage dropped per the setting recommendations and with the small amount of play the gear has under load it was falling out of the window of operation and causing missing with couple backfires...
