It's been a couple of weeks since I completed the hydroboost conversion and so far it has been working great. The conversion was easy and straight forward. I can easily hold 8psi where I was struggling to hold 3 psi before .
The only issue I have is an annoying power steering pump whine during low rpm turns. I did the suggested bleeding procedure, I replaced the pump, and I've checked for leaks and found none.
I was going to try some Lucas PS fluid, or trans fluid, but I doubt a magic fluid will help it.
One thing I noticed is the HB to SG box line seemed to be 2 or 3" too long and so it has a little hump in it. It's not kinked, but I wish it was a little shorter.
My reservoir is the OEM side by side outlet.
I've searched and have seen folks with the same issues, but haven't found where someone fixed it.
