line pressure dropping off at higher rpm.
joyce1
Hi
I just freshened trans with a ck rebuild kit and shift kit.
Got in car and took pressure reading on jack stands.
min tv max tv idle max tv 2-3000 rpms
p 90 275 190
r 180 275 190
n 90 275 180
od 90 275 180
3 90 275 180
2 240 240 175
1 240 240 175
Trans was rebuild a few years back by local guy.Had transgo
shift kit 10 vane pump with harden pump rings and high rev
kit.I freshed because od was slipping.
Thanks for any help.
I never took the pump apart.I took pressure reading
before freshing and thought were ok.But I didn't check
them at high rpm before.This my be why it never shifted
right.I've been doeing some seaching think its probley the
pump slide spring.Took for drive shifts good at part throttle
but pressure never goes over 180 at higher rpm and throttle.
Trans only had 5000 miles on rebuild so I thought pump
would be ok.Should have took pump apart and checked.
Will have to now.Thanks
Took trans back out and took pump apart.
Slide springs are fine but pump mating
surfaces scored pretty good.Guess I well
order a new pump monday.
Is there anything else that can cause this?
Thanks.
Hi
p 90 275 190
r 180 275 190
n 90 275 180
od 90 275 180
3 90 275 180
2 240 240 175
1 240 240 175
Its possible the trans vb has the wrong line bias valve in it.
Checked line bias valve same one thats in
ck shift kit pictures.Ordered new pump maybe
have by weekend.Will install and see what happens.
Thanks again.
