MY85pontiac
im too old for this crap!
- May 17, 2002
i am once again revisiting the idea of hopping up a 3.8 sans turbo and i'm considering doing a little port and polish on the heads.
i have a 4.1 intake i'm currently porting and polishing but i know the heads should be worked also for improved breathing. my goal realistically is to have a nice daily driver V6 with good low to mid range grunt. on the exhaust side i'm considering hedman headers but between the intake and the headers i need to work the heads. which side of the heads needs the most work? admittedly i know very little about the heads on these engines other than they're not very good as cast for performance. is it mostly a matter of smoothing out the runners or do they need a good hogging for what i'm intending to use them for? i do intend to shave the heads a smidgen to bump up the compression and the deck as well. i'm figuring about 9:1 would be good with a cam in the .450 lift range. also what about port matching? is it worth the time and effort? again it's for a daily driver not a race car but i want to get good performance out of the engine. i'm figuring smoothing everything out and not increasing runner size would help air flow and keep air velocity up and a cam with a dual pattern favoring the exhaust side would be good also. maybe the edelbrock cam as an example?
i plan on sticking with a qjet for the small primaries and may even use the CCC stuff if possible but if i change the cam i think that would really confuse the computer too much. i dont mind ditching the CCC stuff but i do like being emissions friendly simply because i'm an environmentally conscious person.
i might use a 4.1 instead just for the extra cubic inches, it couldnt hurt.
trans is currently a th350 with a 2.41 gear but i plan on putting in a 2004r and a 3.42 or 3.73 gear.
what about exhaust size? i'm thinking dual 2" all the way back.
