I'm having problems with the LC-1 connector. I've had it break two times already and I think it's because the connector between the LC-1 and O2 sensor is getting too hot and failing (it's under the hood). I would really like to put the connector inside the car, but I don't want to drill a 1 inch hole in the firewall. I would rather run it up and in through the passenger door jam, but the wire coming from the O2 is not long enough. So that brings me to my question...
Is it possible to extend the wires on the O2 side? Are they a calibrated length or is it fine to just cut and splice in some new wires?
