Rubicon 327
Protected by Attack Cat
- Sep 12, 2008
In my search to find out why I lost taillights (not brake) just running taillights I came across an alarm that I knew the car had but wasn't sure how to use and just want to remove to avoid future starting problems. I came across a "CERTAIN" wink wink colored 10/12 gauge wire on the Buick harness that the alarm taps into and when I cut out the alarm found what I figured and that CERTAIN colored wire is the ignition kill and unless I solder that "STOCK BUICK" wire back together the car doesn't start or even turn over.
MY QUESTION..... Is this where most of you all put a super secret kill switch in that "STOCK BUICK" wire and then hide the switch somewhere? Or is there a better less obvious place to tap into that isn't right under the column where a thief is first going to look?
**** Now I'm not expecting anyone to give up special information on this public board that would compromise the safety and security of our cars, I'm just looking for a yes or no answer. I realize doing it would be better than nothing but it's an obvious place for thieves to start looking (under the column) for a kill switch and I'm not sure how I could extend the switch wire to say where ever, with out it looking obvious and not like stock.......I'm talking about a stray wire under the dash going off to nowhere by it's self.
Any info is appreciated and PM's welcome on this subject to keep info safe.
Oh and if anyone has any ideas on the tail lights I'm all ears.......so far I have checked,
1.Fuses on fuse block.
2.Main wire connection in trunk and the ground.... All look good with no corrosion or bare spots and gave them a tug and push and not even a flicker of light.
Have not done any tests with a meeter yet as I got sidetracked with all the alarm wire krap I wanted gone.
My guess is a bad dash switch or fuse link B?....from some searching I have done on here as to a cause. As I don't see anything obvious yet under the dash or in the trunk yet.
I think and am not positive but I think this may have happened after all the work in my sig was done.....I quite sure the lights were working before all this work just not sure about after, and I don't drive it much at night.
Sorry for the long post and thanks for any advise!
