I just got done installing one:
Sure is a lot open space up front:
This should fill it nicely:
And some piping:
Cut some holes (I know the cuts look crappy, I'm still a bit amateur with the plasma cutter):
Massage the stock A/C, oil cooler, and trans cooler lines out of the way:
Blowing through an LT-1 MAF:
Almost done:
I picked up 5psi on the footbrake and around 4psi at WOT vs the stock IC. Pretty hard to drive the car in 17 degree weather though
Unfortunately, I've picked up some compressor surge at around 8psi. Oh well, sacrifices must be made in the name of boost.
And some piping:
Almost done:
