turbofabricator
- Mar 7, 2004
Dennis Hogans '87 T-Type is back to breathing. After splitting #2 cylinder twice in a StageI 4.1 he decided to build his 4.1 StageII on center for his street strip car. Being it was a full S2 engine with an external oil pump, we had to do alot of work to get it ready for install. First was to install TA heads and Champion on center manifold. They required alot of port work to get them to align. I ported them to the 1200 Felpro gasket which required push rod tubes and sleeves in the head bolt holes to seal things up. Then came the timing cover which needed 1/8" machined from the stock 14 bolt timing cover. Then I fillled all the unused oil passages with epoxy . Installed the TA pump cover with -12 feed, -10 outlet, and -8 bypass hose to the fuel pump block off plate. The TA pump required a new intercooler bracket on the pass side. The Champion manifold required a new coil pack bracket to keep it away from the wiper arms. We stepped to the new Duetsch fuel pump and removed all the Saginaw fittings in the entire system. That resulted in a 106% increase in diameter on the return line and a 33% increase in the pressure side. We installed a BG fuel filter by the pwr steering resivior. The car got a new set of Strange adjustable rear shocks, too. It has a 67/65 Precision Turbo, 88 lb injectors, 3.5" MAF, stock ECM with a Eric Marshal chip, Precision stock location Intercoolers. With the same combo on the StageI it ran a 10.12@136 on pump gas and dual nozzle Razor kit.
